Hi to Everyone! Recently joined this forum as everyone seems quite knowledgeable on here and I am hoping someone can guide me in the right direction as I am currently lost!? Please bear with me as I have essentially no knowledge with regard to solar systems and am just starting out. I recently had an off-grid system installed at my cabin consisting of ten 310 watt Canadian solar panels(total 3100 watts), a Samlex power 3000 W inverter, and a midnight classic 250 charge controller, and 4 Rolls 6v AMG batteries.
This was not an inexpensive system and I tried to go with good quality gear. Everything was hooked up by a friend who is an electrician. The system was hooked up to the batteries right out of the box and everything was working great. The cabin is located in Northern Saskatchewan and I would say the panels would receive about 6 hours of direct sun/day this time of year. I decided to go with this size of system for future use but currently the only real draw on the system currently was a microwave used infrequently, a coffee maker, and 6 or 7 led lights.
The System was fully functioning 2 weeks ago and then we received a huge blizzard here in Saskatchewan which covered the panels completely in about 10 inches of snow with temps around -5 F, and I was not there to clean off so there was no power being generated. I then arrived at the cabin a couple of days ago and the whole system is completely dead, no power, and no display on inverter.
From my understanding the batteries are large and good quality and I am very surprised they were completely drained in that amount of time with no draw on them (other than the inverter I guess).
I want to get the system up and running again and I only have a 3000w Yamaha generator so I am thinking my only option is to try and charge the batteries with it. I have looked up how to actually do this and haven't been able to come up with an appropriate method to charge it. One article I read stated that you need to plug into the AC outlet on the generator and then connect to the battery?? It said to run a proper 240 volt or 120 volt battery charger off the generators AC output, however, this article was from Australia. lol. Is this correct?
Basically I am hoping someone can give me advice on what type of charger I can get to charge the batteries up again off the generator because I don't think there is enough sun exposure to do it, and also why the system drained so quickly??
Thank you very much in advance for anyone that can offer any advice!!!!
