Chri5co63
I do like all the responses to the posts on this thread, not only is it helpful to me and my situation, but probably somewhat to each of you to some degree. The more I read and study, the more intrigued I become and the more I realize that their is no limit to all the possibilities in solar energy production.
...according to the manual, that is.
what are parameters 04 and 05
04 | Battery Power to Utility Setpoint | 23.0V (Default) | Setting voltage point back to utility source when selecting “SBU” in Program {01}. When the voltage of the battery is lower than this setting, the output switches from inverting to the utility (generator). The setting range is from 22c – 26-v in 0.2v increments. |
05 | Utility to Battery Power Setpoint | {05} 28.0v (Default) | Setting voltage point back to battery mode when selecting “SBU” in Program {01}. When the battery voltage is higher than the setting value, the output is switched from the utility to the battery mode. The setting range is 24V – 30V, in 0.2V increments * Cannot be higher than setting in {14} |
