Chri5co63
Hello again,
We recently purchased 4 Chins 12v 200ah batteries to be connected in 2S/2P configuration to be charged with a PowMr 3000w 24v Solar Inverter Charger. These batteries will be installed in place of 4 12v Gel batteries (2S/2P). After spending $2500+ for the upgrade, I want to make certain to setup the Charging Parameters in the PowMr correctly. As per suggestion before installing the batteries, we fully charged each battery to 100% with a Lithium Smart charger.
Chins sent us the following parameters for our system, but we feel after going through all the possible parameter settings for the PowMr unit, there may be more parameter recommendations needed. The following is the list of parameter received from Chins:
You will connect four 12.8V 200AH batteries in the way of 2S2P, and the new battery pack will reach 25.6V 400AH
The setting method of MPPT and inverter of 25.6V 400AH lithium iron phosphate battery pack is as follows:
Charging:
Charging Limit Voltage: 28.4V
Over Voltage Disconnect Voltage: 29.2V
Over Voltage Reconnect Voltage: 27.6V
Float Charging Voltage: 27.6V
Discharging:
Low Voltage Disconnect Voltage: 23.2V
Low Voltage Reconnect Voltage: 24.8V
Under Voltage Warning Voltage: 25.6V
From the possible parameter settings on the PowMr unit, the following is a list of the ones that we'd like to have recommendations for:
PowMr 3000W 24V Solar Inverter Charger parameters list:
[08] Battery Type Choices: User-defined LF07 LF08 LF09 (number correspond to # of strings) NCA (ternary lithium battery)
[09] Boost Charge Voltage (_________V, Boost charge voltage setting range is 24V - 29.2V, in 0.2V increments)
[10] Boost Charge Duration (_________min, with a range of 5min to 900min)
[11] Float Charge Voltage (Chins recommended 27.6V) (Set range of 24V - 29V, in 0.2V increments)
[12] Low Voltage Disconnect (Chins recommended 23.2V) (It is recommended to set this voltage BELOW the maximum voltage the battery can withstand. When this voltage is reached, the loads will be powered on after the time delay adjustable in Parameter 13)
[13] Battery Over-discharged Delay Time (________sec, range is 5-50 sec in 5sec increments) (This parameter sets the delay-time after the battery voltage is below the setpoint in Parameter 12 is reached)
[14] Battery Under-voltage Alarm (Chins recommended 25.6V) (Warning that the battery is reaching Low Voltage, range is 20V to 26V in 0.2V increments)
[15] Battery Discharge Limit Voltage (_______V, range is 20 to 26V in 0.2V increments) (When the battery voltage goes below the voltage set-point, the inverter will immediately disconnect and shut down immediately)
[16] Set Equalization Charging (Enabled or Disabled?) (Enables or disables Equalization charging)
[17] Battery Equalization Voltage (_______V, if Parameter 16 is enabled, range is 24V to 29V in 0.2V increments)
[18] Battery Equalization Duration (_______min, if Parameter 16 is enabled, setting range 5min to 900min )
[19] Battery Equalization Time-delay (______min, if Parameter 16 is enabled, setting range 5min to 900min)
[20] Equalization Interval (______days, if Parameter 16 is enabled, setting range is 0 days to 30 days)
[21] Enable Equalization Immediately (Enabled or Disabled?) (Starts or Stops Equalization charging immediately)
[22] Power-saving Mode (Enabled or Disabled?) (if enabled, if the load is null or less than 50W, the inverter output is turned off after a delay for a certain period of time. when the output load is more than 50W, the inverter will automatic start)
[28] Maximum AC Charging Current (_______A, in amps, range is 0 - 40A)
[35] Low Voltage Disconnect Recovery (Chins recommended 24.8V) (This set-point that recovers and reconnects the solar inverter from being disconnected in Low Voltage Disconnect. The range is 20V - 27V, in 0.2V increments)
[36] PV Charging Current (now set at 60A, range is 0 - 60A)
[37] Battery Charging Boost Return Setpoint (______V, in volts, when the battery reaches floating status, it will need to be lower than this setpoint before it starts charging. The range is the (Under-voltage Warning ~ (Floating Voltage-1.2V) for the respective battery)
Also, in the manual for the PowMr unit, we found the following table for Lithium Battery Parameters (as follows):
One puzzling factor for us is in the terminology differences between Chins parameters and PowMr parameters, i.e.. PowMr calls for
"Boost Charge Voltage", but Chins does not list that as such (unless their term for it is "Charging Limit Voltage" (?)) .
We have reached out to both PowMr and Chins for recommendations as to what settings should be inputted for each of the parameters in the unit, but so far have only received a recommendation from the Technical Support for PowMr to set the [08] Battery Type parameter as USER, so that all other parameters can be setup as User-defined.
Is there anyone in this forum that can please help us determine what setting to use for each of the parameters for the PowMr unit?
We are fairly new at this (and are still learning the many technicalities of off-grid power), but have been using our current setup with the Gel batteries fairly successfully since last summer and our recent stumbling across this forum and the videos we've watched on YouTube have helped considerably in our journey with this.
Thanks in advance!
Charging:
Discharging:
Thanks in advance!
