I purchased a Midnite Solar MN3024DIY inverter/charger, I have 4 brand new panels, and a Big Battery 24 V Husky Elite 234AH, 6 KWh battery. would like some help with figuring best configuration for panels. Below are pics of the inverter manual and panel stickers. All components are brand new.
This is a camp that is used mostly during hunting season , also power will be supplemented with generator to pick up any slack in solar charging.
I am not sure which configuration would be best possible configuration , below are what I think are the the configuration numbers if what I figured out is correct.
2 two panel series in parallel - 460 watts, 62 volts, 15A
4 panels in parallel - 230 watts, 31volts,30amps
4 panels in series- 920 watts 150 volts 7.4 amps ( which I am pretty sure is too high of voltage)
Below are pictures of manual and panel stickers, any advice is greatly appreciated.
