k490
That's lot of power probably going to need at least 100 450W panels and multiple inverters in parallel. Look up in your area see how large of a battery system your AHJ allows on the property. I noticed mine only allows 81kw max for residential which is about 5 EG4 power pros. Although I only glanced at it. How many panels did the local solar contractor quote you for? Trying to go completely off grid might not be worth it, but you can easily have a good battery backup system reducing non critical loads. You don't really need a pool pump if there is a power outage, or every AC unit running. Don't buy anything until you have a plan approved by your AHJ and power utility. Were you planning on using Greenlancer for the solar permit design plans?No, i'd said in my original post that I have used as high as 8000 kWh per month. Then after I got the charts and posted them it is around 5000 - 7000 kWh per month depending on the month.
If you connect a 50 amp inverter to a 200 amp panel have to reduce your grid main breaker so the max bussbar does not exceed 120%. 200 amp main bussbar max current allowed for that panel is 240 amps. You have to reduce the main to 190 amps to connect the 50amp EG4 18kpv. Not sure you can find a 190 main breaker. You would have to reduce the breaker down whatever you can get another method is conencting in the supply side before the main using a tap. You want to hire a electrican to do all this if you can find one who will work with you. You could upgrade the panels to 225 solar ready main service panels that gives you enough bussbar overhead. That's what lot of new homes coming with solar ready 225 amp panels.
