Sorry to dive right in, but I am a bit frustrated.
I started my solar journey by sourcing all of the components after doing lots of research.
After many road blocks, I decided to get a company to install it and go through permitting and the hassle with the local power company.
So the short of it is... they are saying that the inverter is bad. I disagree and need some perspective from others.
Inverter is an SMA SB 6000TL-US. Yes, it was bought used, but it was in production. Has KW/h showing on the total production line on the display.
Unit will "power on" when the AC is connected. LEDs flash, then after 15-ish seconds, the system goes into a standby type status. The display will light up when you knock, but no production has happened since install.
I have checked the voltage from the string at the round on/off switch box and it is showing around 8 volts. This is before the switch and after (going into the inverter). To me, that says they are in shutdown, or something, and that is not enough voltage to "turn on" the system to start production.
I have looked at the varistors and the whole system, and everything looks clean. No burns, no exploded parts, etc.
Thoughts, ideas? Many thanks and I will be happy to give more info on the system if you can think of something I missed.
