GridWorks Green Solar
Solar Innovator
5 full days of system voltage controlled load management and system voltage power board crash protection.(One single $11 DC voltage controlled relay is handling this decision)
When compared to full sun detection method or letting the power board determine what it can and cannot handle in any given situation I have determined that the system is providing more hours of PV power in overcast conditions, Not just a little more but hours more at a time.
The relay protection simply will not allow the power board to crash and the secondary ISO makes for 550watts soft landing, Runs day after day without intervention and getting more mini split PV up time than ever before.?
I use to think it was all about full sun conditions, what I have learned is it is all about your volt+amps needs VS what the system can actually provide at any given time, this is a big step forward in real power production and day to day reliability.![Red heart :heart: ❤️](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/2764.png)
You should take another look at the project system with voltage controlled load management, should have tried this a long time ago.
New favorite set point is 73 degrees Fahrenheit the AC runs more in overcast conditions.
This was an accidental discovery when the solar sensor was being worked on and lagging in operation,allowed a full day
of mostly PV operation of the mini-split in sub par overcast sky conditions.
Love how the system waits till it gets the full sun power 115 system voltage before attempting to restore the larger loads.
Within 7 minutes or less of full sun conditions the largest loads return to the power board, taking advantage of every opportunity to run on solar ?
More later
More later
