Rednecktek
Solar Wizard
Just want enough power in the winter to run heaters and
no electric heat
The general consensus with heating is "Anything But Solar!" because the power draw kills batteries right quick! That battery you're looking at is good for 48v * 90Ah = 4Kwh best case. A bog standard heater wants 1500w, so 4000Wh / 1500w heater = 2.6 hours of heater and a dead battery the rest of the night.
A propane based heater will be a much better option, or if you're willing get a diesel heater mounted in there which is very solar friendly AND heats the place up right quick!
As long as you're not trying to charge it when it's frozen, it'll sit there just fine for however long you want it to.Oh one more thing is the ampertime server rack 48v 90amphr ok just sitting in my garage over the winter not being used??
Keep an eye on the weight when you're looking at mounting panels. The weight of the panels is usually available online so you can always run a test by putting some gallon jugs of water (~8lb ea) or 5 gallon jugs (~40lb each) and do some test runs. If the panels weigh so much that you can't get the pop-top up, you'll have bigger issues.
