Hi all I'm planning on making a 1000 watt solar panel from 200 cells myself to save money
Each cell has an output of 0.5 volts and 5.3 Watts. So the total output from the solar panel will be roughly 1000 watts and 100 vdc volts. I want to be able to charge 4 12V 100ah lead acid batteries at the same time.
I was wondering what inverter to use for this setup. Much advice would be appreciated also I don't want to spend a great deal of money either.
I've searched and searched and searched and all inverters I find for reasonable price all seem to suggest a maximum voltage input from the solar panels from 30 vdc to 80 vdc which is not enough for the size of the solar panel I want to make and the voltage it will output. Thanks in advance for any suggestions
