thomBangor
Hi, I'm trying to design a diy solar system to put on my garage roof in Maine, that will reduce the power I buy from the power company.
I think I would like to include an outdoor-type battery like the outdoor EG4 powerpro, so that I can store my solar power for use at night.
I would prefer not to net-meter for the moment. I believe that means I need a gadget that prevents power from backfeeding to the grid.
What gadget do I need to prevent the backfeeding?
What I have in mind so far is three groups of: 5-hyperion-400W-panels-in-series. Put that into the three (??) DC inputs of the Growatt 6000 or 7600 MIN TL XH-US. I would mount the Growatt inverter on the outside wall of my garage (is this ok?).
Plug the Growatt Min's battery charger into a EG4 PowerPro WallMount AllWeather.
I read in this forum the Growatt Min has a battery output and input, and read some about it in the spec, but would really appreciate knowing whether this actually works?
The spec for the EG4 PowerPro claims that it is seamless with Growatt - is this true for the MIN?
The Growatt Min claims it has a shutoff for arc faults in the panels- is this true and if so do I still need a DC fuse/breaker for the panels?
My final question: SignatureSolar calls this Growatt Min a grid-tie inverter. Since it does batteries isn't it a hybrid inverter? Is there somewhere one can go to learn what off-grid, hybrid, and grid-tie really mean in technical terms?
Any thoughts on which is inverter better for my situation - off-grid, hybrid, or grid-tie, and if so which one?
Lots of questions, thanks for your patience.
