I have this portable solar panel:
which I use to charge this:
I wish to purchase a pair of cables in order to place the solar panel about 20ft (6m) further away from the battery pack than I can at the moment.
I live in the UK. Would this cable suffice:
and would I need the 10 or the 12AWG? (I believe that AWG refers to the thickness of the cable, smaller numbers being thicker?).
If I later needed a longer distance could I then buy another cable and use that one as well? Is there a downside to using such extension cables?
(The reason doing this is that that battery weighs 20Kg and it would be much easy to have a longer cable than to move the heavy battery).
I think the solar panel is this one, which says it has an MC4 connector so I think the cable should be the right one:
Thank you for helping out this solar power newbie.
POWEROAK SP200 Portable Solar Panel 200W Foldable Photovoltaic Solar Module with Monocrystalline Solar Cells to Charge Portable Power Station Solar Generator for Campervan Travel : Amazon.co.uk: Business, Industry & Science
www.amazon.co.uk
Male to Female Solar Extension Cable( A Pair)
The Renogy MC4 Solar Extension Cable allows you to make spatial adjustments to your solar power system in one simple step.
uk.renogy.com
Bluetti SP200 200W Solar Panel
Durable and Waterproof: "Made with Advanced Laminated Technology and The Long-lasting ETFE Material on The Surface of The Solar Panel Make It Longer Life, It Is More Anti-scratch and Durable, Lighter weight, The Light Transmittance Is 95%-97% with Excellent Transparency, It Is Manufactured in...
bluettipower.co.uk
