MisterSandals
Participation Medalist
Yes, sorry different from what you specified sorry. But, i have this battery setup and its been flawless in my RV for 2 years now. There are a bunch of us here that do it this way. It lets you us a single BMS but you are limited by the current of a single BMS. With 4S2P (2 batteries in parallel, each with a BMS), the amperage is the sum of them (and presumably they are the same).The photograph i think shows 8 cells into 4 12v out ...
Oops, another swing and a miss. Sorry, i thought this was the model that was also a charger and therefore needed a power source. You're good to go as yours does not need anything other than balance lead and +/- connections.What do you intend to use as a DC power source for your BattGo?
That is a nice little meter. It will do balancing but very slowly. I think the most powerful feature are the alarms when you can have it beep if it gets over or under charged, even at the cell level. Handy if you are doing something without a BMS (i was my own BMS for several months before i found one i liked. its a tough job that requires attentiveness and some alarms to keep from catastrophic results).
