Can you test the output signal voltage from the smart shunt? As I'm wondering if it is giving out full battery voltage which is feeding into the RPI.
And you did say the battery/shunt is not connected to the RPI power supply?
Yes, now, when the BMS is “open”, it’s just app 2.5-3v between the communication port of the smart shunt and (1) the minus pool of the battery, (2) the USB port of the RPI and (3) a minus pole of the 12v system.
It sounds like current leaking between the two systems. Which means that there is another connection between them to complete the circuit.
Yeah, how, when and where I don’t know.
The 12v system is one option, it’s connected through (a) one of the RPIs getting it’s power from it, and then there is a COM/MBUS cable from the EPEver charger to the other RPI that runs Home Assistant. This RPI is powered by the 48V system (230 cable). In addition, the RPIs are connected with com cables to the MPPT, the BMS, the MP2, the SmartShunt (the cable that burned up), etc.
But with both RPI surviving without a scratch, I wonder if the power must not have gone from one USB cable to another?
This is how it looks now, but it’s of course impossible to get a detailed overview from a picture.
Jävligt mycket/en jävla massa I think is the right term
As
@Hardergamer1 just mentioned, I think it's time to do a close up on the wiring diagram. This together with you noticing it stopped charging for some reason, and the battery completely draining,...
Haha, exactly my thought, would not have expected that if I shorted a car battery…
Yeah, I need to check it up.
Where should I start? Any measurements I can make? Should the BMS discharge be off?
