Hi all, just wondering what form of breaker/protection people use on the AC output cables that run from their inverters to the CU/board?
I'm thinking... the AC out of inverters is usually rated up to 50 amps, but if for example, in your board you had two rcbo's rated at 32a, then running both of these could overload the cable (depending on the gauge) and the inverter?
In houses there's a fuse on the cable that feeds the mains supply, so surely the cable from the inverters AC out needs a fused connection as it's effectively a new mains supply for your off grid board.
Also, do inverters themselves generally have an auto cut off if the ac output is overloaded? If so, the cable itself wouldn’t need protection, providing it was the correct gauge to handle the load. Thanks
