Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,795
True, but my 6kW 95% efficient inverter is only a 300W heater. It could deliver 6000W to resistance or heat-pump.
DC direct and solar thermal will have their applications, but water heating is an afterthought for most home users. So electric, even resistance, makes sense. Space heating could be a major application, too bad so little sun in the winter.
An off-grid system would ideally have surplus PV at least in summer, so water heater as dump load (AC or DC) is a no-brainer. I would prefer variable load rather than cycling batteries.
There are some DC water heater controllers that drive PWM (accomplishing PV MPPT into a resistive load), with pulsed DC so thermostats should work fine.
