DougfromdaUP
This is right in line with what I've seen with my 30" self cleaning. While you're drawing a couple of Kw steadily while it's preheating (mine is more like ten minutes,) the insulation is so good that once you're up to temperature it cycles with pretty short "on" periods. The outside is cool, even on top. Once you heat the insides it doesn't take much power to keep it at temperature.2200W seem to be pretty much standard in here. To burn frozen pizza in our oven it takes about 16 minutes with pizza put in cold oven.
I'd estimate that getting up to temp takes maybe 8 minutes and after that the oven is cycling at 30% power.
Maybe 400Wh to bake a frozen pizza in that case.
Just don't run the self-cleaning cycle between November and February. I hate the smell anyway. I line the bottom with tin foil....
