Basselaz
- Aug 17, 2021
- 4
Hello...
I have an older Growatt SPF 50000TL HVM that doesn't have neither a BMS or a CanBus or an RJ45 Port... I currently have two inverters connected in parallel for 10Kw output and Flood Lead Acid batteries
I want to upgrade to Lithium but found out that i have none of the above ports for safe communication with the batteries. Is there a way to connect Lithium batteries safely to my current setup? Adding external BMS or something? Any support will be appreciated
Bassel
Bassel
