I thought I would post what I think are some pros and cons of the Orion Jr 2 BMS. I have been running it for about 10 days now.
Pros:
Pros:
- Very accurate monitoring of cell voltages and DC amps
- Many many settings and options allow you to customize everything to fit your needs
- I can connect a laptop to it to change settings, monitor cells, log data over time.
- Cell balancing.
- Multiple configurable outputs that can be used to control relays for disconnect, charger enable, most anything. They can only sink 175 ma max so relays are needed for most things
- BMS comes in an enclosure (not a bare PCB)
- Uses voltage and amps in/out along with user defined voltage/SOC correlation points (drift points) to calculate an accurate SOC
- Produces error codes and event logs to help diagnose problems.
- Complicated. This BMS is designed for EV applications mostly so it has a lot of options and controls that I probably will never need. Took me several days to mock up a small bank, get the BMS working, move it to my big bank, set everything up. Three manuals to learn.
- No LCD on the BMS to display basic status info such as SOC. You can buy a simple display but it is bare bones.
- At the present time, customer service from Orion is severely lacking to non-existent. Can't speak with a tech and several of my emails have had no response as of today (several days after sending).
