Brightside and @
MizzouMookie thanks for replying and providing information. I want to ask two questions from both of you. When you say “
they will not start balancing until cell voltage is above 3.4 volt”, are you really referring to SOC being close to 100%??? I am asking the question because all the individual battery cells in each EG4-LL V1 are balanced within 0.002 volt when the batteries are either charging or discharging
AND SOC is less than 98%. 2nd question: Are you also saying that in the future, I could increase my Absorption voltage to higher than 54.8 volt (see below) because the cells are more balanced (behaving better) and they will not hopefully overcharge to 3.9 volt (62.4 volt=3.9*16) and activate the Cell OV alarms? Please keep reading…
Brightside I followed your instructions and increased my float voltage to make the individual cell voltage to go above 3.4 volts.
Your Victron shows Float. So you are in Float with a voltage of 53.60V. You need to raise your Victron Float setpoint up to 54.somethingV to get your high cell/s above 3.40V so it will start balancing.
Brightside I followed your instructions and the Absorption voltage of 54.8 volt would keep the cell voltage from going higher than 3.65 volt.
You just have to go with lower absorbs for now. Like I said, just absorb to something around 54.5V and try to keep your high cell from going much above 3.65V during absorb. So monitor that cell while the voltage is rising during absorb, when the cell is around 3.65V, take note of the pack voltage and make that your absorb setpoint.
Brightside I noticed the squares in the lower right corner of BMS_TOOLS software would start turning green
ONLY (in Stand By & Charging modes) when the SOC is approaching 100% (>98)
AND if the individual cell voltage is > 3.40 volt. Note, the software cycles between all selected battery Packs, therefore it is recommended to have only one battery Pack selected in the upper left corner of the screen.
You can also see no cells are balancing because there is no green square lit up in the lower right corner of your BMS tools.
Brightside and @
MizzouMookie I really appreciate for your inputs and what you have said for me to do and what you have done yourself. I have been watching the BMS_TOOLS software over ten days, and if allowed, a single cell in battery Pack # 3 overcharges to 3.9 volt. If the balancing @ 100% SOC is not going to make this individual cell to behave and overcharging in the future, I hate to say that I may have a bad cell. I have come to this conclusion because as you can see from the posted BMS_TOOLS screen captured (see blow), I now see cell voltages above 3.4 and even 3.5 volt in other two battery Packs but I don’t see their cell voltages keep going up until the Cell OV is activated. In conclusion, I could keep my Absorption voltage at or below 54.8 volt and say enough wasting time, wait for a few months to see, if that cell starts to behave before increasing the Absorption voltage higher than 54.8, disconnect battery Pack # 3 and increase the Absorption voltage to confirm Cell OV alarm will not be activated by battery Packs 1 & 2, etc.
This BMS_TOOLS software screen capture shows battery Pack # 1 cells are balanced within 0.002 volt and the squares in the lower right corner are not green. This is what I normally see in each battery when the SOC is less than 98% and the batteries are either charging or discharging.
This BMS_TOOLS software screen capture shows battery Pack # 1 cells at 100% SOC and the GREEN squares in the lower right corner are for cells with voltage > 3.4 volt. The squares turn green (in Stand BY & Charging modes) when SOC is getting close to 100%. As you can see, the cells are behaving and they are not (overshooting) overcharging to 3.9 volt and activating the Cell OV alarm.
This BMS_TOOLS software screen capture shows battery Pack # 3. If Absorption voltage is set to higher than 55 volts, the cells # 03 will continue to overcharge all the way 3.9 volt and activate the Cell OV alarm. Again, GREEN squares in the lower right corner are for cells with voltage > 3.4 volt. The squares turn green (in Stand BY & Charging modes) when SOC is getting close to 100%. As you can see, the cells # 03 voltage is already higher than other cells at 3.64 with cell Pack voltage at 54.79 volt.
