Roswell Bob
I am about to bring a good size 48v LiFePO4 array on line with new Midnite Classic 200 charge controllers. I have been using some Make Sky Blue controllers on my existing Lead Acid array. I have not had such good luck with these controllers. I get these big fat sparks when I connect them up and expect that they may be failing at this point....maybe.
I believe that these MPPT controllers are basically buck converters with some fancy control algorithms to find max power point.
I recall that the recommended way to hook up is to make connections to the battery first. This seems backwards to what I would expect. This is what I don't understand. I assume that there is a good amount of capacitance on the primary side of the controller which the PV array connects to. Connecting the (low impedance) battery array to the controller would cause a large current to flow through the reverse diode of the upper buck transistor to initially charge the input capacitance. This kinda scares me a little bit.
Is my analysis correct, and is this anything to worry about?
Thank you.
Thank you.
