Hi from sunny Queensland Australia...
Offgrid again (first time back in the 1980's- things sure have changed since then lol)
Currently running a 'temporary' setup with two arrays of three series 250W ex gridties totaling 1.5kw (picked up 18kw worth of panels (72) for under two grand lol) but they are sitting in the shed until I finish building the house to put them on... until then, my little 'temporary' setup runs the shed and caravan...
![1706911142776.png 1706911142776.png](https://diysolarforum.com/data/attachments/192/192894-3cacc401456088493a2d1ee562fdeef6.jpg)
Three in series facing north at the right angle for summer/winter collection, 3 facing west at 45 degrees for the afternoon sun... Together they put about 7.5-8kwh a day into the battery bank, sufficient to run the caravan and shed... Strapped down to two full IBC's- they aren't going anywhere with 2 tonnes of water ballast lol
![1706911273625.png 1706911273625.png](https://diysolarforum.com/data/attachments/192/192895-259e01275587dd61133f524730373785.jpg)
The fourth panel (right at the top) runs a UV sterilizer and 'stirrer' pump in the rain water tank behind it- they only need a 20w panel- but buying one was going to cost more than I paid for the 250w ones lol- and I got plenty sitting in the shed idle atm...
![1706911574875.png 1706911574875.png](https://diysolarforum.com/data/attachments/192/192896-6e0d972a67d0f1139a398d89ced79194.jpg)
Feeds 16x 400Ah (20kwh) of LYP cells- currently 4S4P to run at 12v feeding an old 8kw 12v inverter I've had for nearly a decade now (LYP are LiFeYPO4, similar to LFP, but far more tolerant of temperature extremes (we get upwards of 40C plus for weeks on end in summer here- over 100F) and with the LYP capable of charging from -45C to 85C (-50F to 185F), and LFP needing to start reducing their charge rate above 40C- the LYPs made better sense even though they are slightly more expensive than LFP...
During setup at the shed
![1706911947602.png 1706911947602.png](https://diysolarforum.com/data/attachments/192/192897-0b69f4ce6d0aad26fdcc9b60e3e3f8a5.jpg)
Feeds the battered old 8kw 12v inverter (years of being mounted in the back of the ute has given it a bit of a battered look, but still works as good as the day I bought it back in 2014...)- there's a 48v 12kw hybrid inverter also sitting in the shed for once the house is finished...
![1706912607684.png 1706912607684.png](https://diysolarforum.com/data/attachments/192/192899-33ec3e5fd3aa625a25fdf57ae10d7ffc.jpg)
Heavy sucker- took three of us to get it into the cab- used the winch on the tilttray to unload it- it weighs in at 72kg (160lbs)- wasn't going to drop a brand new inverter!!!
I know that 8kw on a 12v system isn't ideal- but stayed at the 12v because all the caravans electrics are 12v (lights, TV, water pumps for the sink and bathroom- the house will be 48v with the battery bank reconfigured as a 16s instead...) and it is only 'temporary' (mind you, it will probably be 'temporary' for another couple of years before I finish the house lol- took me a year to build the shed...
