FilterGuy
Solar Engineering Consultant - EG4 and Consumers
In a separate thread about inverter efficiency, @mandrews44 brought up the point that there is often a lot of power savings to be had by doing power factor correction on our equipment. We were getting way off topic on that thread so I thought I would start a new thread.
@Mandrews also posted this interesting video:
He brings up a good point..... and it is not just motors that can have a crappy power factor. I tested my Comcast Cable box and it had a power factor of only .61
My Dell laptop was much better at .91.
I have known about power factors and how it 'wastes' energy for a long time, but I have never really paid much attention to it. Since the cheapest energy is the energy you don't have to generate.... this is an area of opportunity for improving the effective efficiency of the system and getting more effective use out of our batteries.
If folks have good ideas on how to address this, let us know.
the first problem I have with AC circuits today is the lack of active power factor correction. From LED lights to TV's, none of them have any power factor correction and some of them have a PF of 0.50. This means I have to provide a 50 watt lights with 100 watts of AC power due to their conversion inefficiency that normally is not noticed when used on grid. My Renogy inverter uses < 1 amp when idle and is > 85% efficient. It makes more sense to me to fix the loads that use inefficient switching power supplies before looking at the inverter. I have a pool pump that used to pull ~528 watts off the inverter/generator and only 330 watts off the grid. Adding a 80uf cap dropped the battery draw to about 350 watts.
Without changing the inverter, I dropped the battery draw by 180 watts by fixing the power factor issue, not the inverter inefficiency. Even if the inverter was 100% efficient, a 0.62 is still a 38% (200 watt) waste of energy to run a 328 watt device. Power factor of switching power supplies is even worse and much more difficult to overcome. My 75amp charger is a unity PF of 1.0.. IOTA 55 AMP without APFC draws more amps off the generator than the 75amp with.. That is what I'd like to see go mainstream, An adjustable APFC box to add to switching power supply loads that waste my solar power.
