Got the powmr 60a mppt charge controller and I am wondering about the voltage setup. I'm using a 24v AGM battery setup. What I have read is the batteries should be around 26v at full charge
When the controller is set on sealed lead acid battery the voltage raises up to 28-29v. Is that voltage too high for these batteries?
I changed the setting to user defined and set each setting.
24v
Boost charge 26v
Float charge 25.6v
Cut off recovery 24v
Cut off voltage 23.2v
Do these settings look good or should some of them be changed?
I was using the attached chart
If I went by the chart in the manual the boost charge and voltage would be set to 28
24v
Boost charge 26v
Float charge 25.6v
