timselectric
- Feb 5, 2022
- 19,948
The wood racking is a good thing. Because there is no conductive path between the frames and the earth.
The ground plates and bare wire in the ditch, take away this benefit.
#6 is code for exposed to physical damage ground conductor.
So, #6 from panels to the combiner box. And a single #10 from there back to the cabin.
Not sure how your conduit is ran. But if you go from one array to the other, and then back to the cabin.
You only need one grounding conductor in each run.
