dmkjr
Looking for some recommendations. About to start a decent sized install for a friend. There are several large oak trees on her property which is going to cause some issues for the ground array we are installing. We are looking at 16kw array and the best place to install is roughly 420' away, with a max of 460' if we go the long route to ensure to stay away from other utilities.
The array will roughly be running at 400v and 16 amps or something near that with two (or more) PV's. This will be running to an EG4 18kpv system installed in the garage at her home. What is the best way to get the power from the array to the house? We will be burying conduit for the pathway.
thank you!
thank you!
