Its a good idea especially if your array is distant. You can though have an isolated system and nothing wrong with that, especially with roof mounted solar.
A ground rod mainly protects utility supplied power systems, but if you have a large web of wiring basically suspended in the air and are not confident in dc lightning repel, a single point ground rod would give a place outside your home for stray voltages to drain. Static and other charges.
