rjolicoeur
I have several questions about over-current protection. I’ve included a diagram of the array I’m planning at the bottom of this post.
Thank you for your assistance!!!
- All the MC4 style fuses that I’ve found online have a 1,000 V DC rating. As long as the amperage rating is correct, would a 1,000 V DC fuse work for an array that only generates around 120 V?
- All the DC circuit breakers I see online have lower voltage ratings (12V, 24V, 48V). Would they work in an array that generates around 120 V?
- For a 4S3P array, does the Isc amperage of the individual PV panels in the series connection determine the fuse size required?
- In my case, each of the four panels in one of the series connections have an Isc of 5.21 amps. Would a 10-amp fuse be the correct choice?
- Should the fuses be located at the point where the positive leads become a parallel connection?
