What's your bulk charge value set to on your solar charge controller?Here are my settings. Been on 98.8% for over an hour now.
Should I change anything?
Thanks.
28.6V, float at 27.5VWhat's your bulk charge value set to on your solar charge controller?
What voltage is your shunt currently reading?28.6V, float at 27.5V
I Sync'd it yesterday as it wasnt resetting. But yeah, I'll try lowering the voltage to 28V.I would manually sync to 100%.
And see what happens tomorrow.
If it still doesn't automatically sync. Maybe lower the "charged voltage" to 28v.
Battery SOC on reset controls what you want the shunt to do when it loses power.Is the ‘Battery SOC of reset’ option supposed to be set to keep SOC? I thought reset meant when it hit all the parameters this is the option that tells the shunt what to do. I have mine on reset to 100% so every day when the parameters are met it resets to 100%. Or is reset supposed to mean power is lost or battery disconnected and reconnected?
It used to do it automatically before the last update and I havent changed any of the settings since setting it up.
- "Keep SOC" means it's gonna remember where it was before it lost power.
- "Clear" means it will blank the value out and you have to manually set it.
- "Set to 100%" means any time power is lost to the shunt and it comes back on, your shunt will read 100% SOC.
Yes, has been for days. Gets to 28.6V about 1-1:30pm ish.
As mentioned earlier, its only started happening since the last update.
I have always assumed that was with the Bluetooth turned off, but I guess it's not?Victron rates the Smart Shunt and the 712 (with the backlight off) current draw at less than 1mA.
