I am replacing an old GE 125 amp load center with a new QO square D main breaker 200 amp panel
I have a fused disconnect between the meter and this new panel, so that makes the new panel a sub panel with a 4 wire feed and no bonding at this panel. neutral and grounds will be separate in this panel
I have never used a QO panel before and want to be sure the 4 feed in wires are correctly mounted its 4/0,4/0,4/0.2/0 AL
in the picture it looks like the 2/0 ground goes right next to the neutral wire. Is that correct ? looks like the neutral and ground lug are the same piece of metal, isnt that a bond that I do not want ?
my old GE panel needs a separate ground lug for 2/0 wire added to the ground terminals
like this one from QO, do I need this lug ? QO says its for neutral doesnt say ground ?
bottom line how to do a 4 wire into a qo panel ?
