Sam Cho TX
I'm just going to say this: taking the Wh reading of your measurement and dividing it with the nominal voltage of the cell or battery is just wrong.
I have asked around some folks at Texas A&M regarding this and this equation: Watts = Amps * Volts is a very reliable means of calculating power and if you have 2 values you can get the third. The same applies to Watt-hours = amp-hours * average voltage.
https://en.wikipedia.org/wiki/Volt-ampere#:~:text=Volt-amperes%20are%20usually%20used,⋅A%20%3D%201%20W).
So if you have any 2 values you can get the third.
