fgerin
Hi,
I'm looking for some raw logs of RS485/Modbus communications between an inverter and its smart meter for both Sofar and Growatt hardware. (The most important for me is Sofar's hardware, since I'll have access to a Growatt one in August, thus will be able to record the logs myself.)
Both 1 phase and 3 phases are of interest for me, but highest interest/priority goes to Sofar 1p and Growatt 3p.
Context:
Zero Export feature of inverters requires a meter, which may be external and/or internal according to the make. Sadly, often the resellers just sell the inverter and there is no way to get the compatible meter... Great, really, especially when you get the information late after buying the hardware that you chose especially for that feature! Yet more when the maker also is non-cooperative at all, telling you to buy some smart meter that, in the end, is not compatible! No support, no reaction to mails or just some to send you towards no-exit directions, no matters the subsidiaries or HQ.
In the end, Growatt just uses the usual Eastron meters and Sofar uses Chint and Solarman meters. BUT, in both case they change the firmware of the meter, so that a genuine Eastron or Chint cannot work with the inverter. (Oops, we "forgot" to mention... So sad.)
On their side, Eastron like Chint were very cooperative, and I'm happy that my money went to those companies and not Growatt. But they have no knowledge or cannot disclose the information regarding the modifications from Growatt and Sofar.
After 1 year of endless attempts with Growatt and Sofar, despite being one of their customers, now I decided to hit back...
To sum up, they irritated me enough for me to write a software to bypass their smart meters and use any other make I have info for. Both Eastron and Chint are already implemented, thanks to their cooperation.
It is just RS485/Modbus, not rocket science, no room for "trade secret" there. Still, they continue to FU** us, their customers.
I just need the registers map they're using... I should be able to guess it quite easily if I can get some raw logs from a working system, preferably with matching info (amps, watts) at the same time as the logs are recorded, but it is not mandatory.
Also, since they implemented some traps, the logs should begin from the start of the inverter and then for several minutes at least. (>16min would be great, but I would already be happy with 5 minutes!)
If someone can provide me with this, it would be greatly appreciated.
Thanks a lot in advance!
Context:
