Yes, they merely have to be right more often than they are wrong to make moneyInsurance companies arent in the business to lose money either..
Does not imply they know the quality of each battery
They probably didnt just roll the dice.
Wow, no the conclusion I had publicly written up which you conveniently left out for whatever reason was ...Summary: Battleborn tells you to charge to 100% only because they have a warranty and dont think their reputation matters, and that warranty is meaningless because they're insured, and the insurance company just charges a random over-priced rate that gets built into MSRP so battleborn can fool everyone into ruining their batteries.
I don't understand why my post asking about the efficiency loss real world round trip is causing such an upset; hehe.
if just using those cells in serial and one dies, the whole battery will go kaput (but of course it's WAAAAY cheaper and also fun to DIY).
OK so I just watched a video where Will tears down a BattleBorn and it turns out our theory was correct!
The battleborns absolutely have MORE capacity than they rate the battery for but the BMS keeps part of the bandwidth out of bounds.
That is why (as I postulated earlier in the thread), their CEO encourges people to cycle to 100% .. because the cells are NOT actually hitting 100%. The BMS is protecting that zone. It's a smaller margin than I thought but we also speculated that the warranty surely allows loss in capacity after 10 years.
At 6:38 Will concludes, "So with battleborn they overshoot the capacity so that they know that everybody will always have that capacity and they'll have an improved charge cycle life." That's exactly the point I was trying to get across (as a theoretical way to reconcile the Battleborn warranty with the scientific literature and sure enough; the 2 are not at odds!
Other markers to this effect in the video are 3:30 and 6:21.
It's a great watch for others who are designing their own batteries. One Cool thing is that the Battleborn's don't use Prismatic cells; there are like 40 small cells in parallel (per cell serial grouping) so that even if a cell dies, the battery will still work (again, I'm guessing the warranty doesn't claim 95% capacity after 10 years but that the battery will still work) and this will make it work. Those of us building our own batteries out of the XUBA or Dongguan threads; if just using those cells in serial and one dies, the whole battery will go kaput (but of course it's WAAAAY cheaper and also fun to DIY).
Yeah I've seen that video, thanksThey rate 100ah so you can use 100ah keeping you from discharging below 10%. That doesnt mean youre not charging to full. Balancing requires the cells to reach 3.6v - 3.65v to balance.
Thats called "top balancing."
They could certainly have the BMS cut off charging at some value bellow 3.6v leaving 100% capacity forever out of bounds.The only way to hide capacity would be to have some bit of electronics inside the case that would somehow increase the battery resistance to increase voltage and stop charging. It would have side effects I'm sure....
They could but they don't.They could certainly have the BMS cut off charging at some value bellow 3.6v leaving 100% capacity forever out of bounds.
