120 Voc is good, leaves 25% headroom to 150V limit so very cold days aren't a problem. Calculating with the temperature coefficient of a given panel you can design it a bit closer to the limit. I use 16% for my location and panel specs.
You can over-panel well beyond 2000W (STC) of panels. Their actual (PTC) output tends to be about 85% of label rating. Peak output only occurs during full sun at the optimum orientation. Charge controller will simply limit output if more PV wattage is available. Multiple strings of PV panels (all same length) can have different orientations and all be paralleled. It would not be unreasonable to put 3000W to 3500W of panels on the charge controller. With multiple orientations you'll get 2000W for more hours.
I selected SunPower, which he had at he time.
Although new panels may have 20 year manufacturer warranty, if you get a quality brand a few years old for cheap, SanTan's 1 year warranty gives time to make sure they are good.
There are differences in quality and some things cause panels to die young. Wish we had a reliable source of info on them.
In this thread I posted a link to reports for many years. It doesn't name names for poor performers, but it does list many top names for each year tested.
Well that sounds like a heck of a deal! Glad you placed your order and can't wait to see how it all works. That is a very good price, and I should not be surprised but that confirms they get a great deal when they upgrade. I wonder if they went with Trina on the replacement units? Any idea?
diysolarforum.com
