cody0r
Currently I have an Ecoflow Delta 2 + Extra Battery and it is connected to two solar panels to max out the 500w charging on the XT60 input.
I wanted to have charging coming into the AC input but I wanted that charged with solar as well.
So I have a 1000w Renogy Inverter connected to a 12v Renogy Battery, Renogy 60A MPPT, and another larger solar array. I was hoping to use this existing setup to also charge the Ecoflow Delta 2 via the AC input, just like it does when connected to outlet in the house.
When I connect it, I get an immediate Ground Fault on the Inverter and it will not charge.
Could this just be a grounding bond fault?
Is there anything to keep this from occurring?
