scott harris
- Jan 1, 2020
- 98
I have a 8s battery built with 280AH prismatic cells. I have decided to replace a poor performing cell but the replacement is about 2 mm taller than the others. Can I place a washer between the busbar and the terminal of the two neighboring cells to make up the difference? The washers are common washers made of steel i would guess. I am afraid that the conduction of steel, being lower than the terminal or the busbar may cause a problem.
Thanks,
Thanks,
