I need one replacement solar panel to match the rest of the systems panels. I can’t seem to find one. The damaged one is a REC285TP2 BLK. Your advise is appreciated.
It kind of depends what is connected to your panel. are you running a series connected array or parallel, are you connected to a 600 V max inverter or 200 V max system or is this on a charge controller by itself?
In other words: since you can't find an exact replacement to match can you at least find one that fits in with the rest of your system?
In which case, we need to know a lot more about the rest of your system.
