Hey thanks for the reply. I've been thinking about this for a few days and thought I'd ask for your opinions as I'm not overly experienced with these systems.
The more I looked into the 5000ES the more it made sense, 240v makes it overland ready in most other countries, I don't even have any 110v appliances as all of my stuff is from Europe or New Zealand. It's got a fairly low idle consumption (70w) in comparison to 2x 3000w EG4-48 inverters, and can use appliances and charge batteries while hooked up to 240v mains, and at the cost of one unit rather than two! The only issue that I realized is the MPPT operating range is 120v-430v, I haven't put solar on my van yet but with the array I'd be looking at 600-800w to start out with, and with the configuration of panels I don't think I'd be anywhere near 120v for the minimum MPPT input. The same thing goes for two EG4 3000w wired for 240v, and I'd need to have 2 units on idle consuming like 150w to even charge the batteries with solar (I could be wrong about idle consumption while just charging batteries through solar?
I thought a potential solution could be 2x Growatt 3000w-24v wired for 240v. The PV MPPT range is 30v-115v which is much more achievable with such a small solar array. But then I'm back to the con of having two unit's with a high idle consumption (especially with only 600-800w solar), but it would make a huge difference if the inverter didn't have to be on at idle in order to charge the batteries. 24v does make things a bit easier to charge batteries from the alternator though, as it's easier to get a 24v alternator than 48v.
Alternatively I could just get the Growatt 5000ES and run the solar panels through a separate MPPT solar charge controller to the batteries. This way the batteries can charge without the inverter being turned on, and I wouldn't be able to charge the batteries through the built in MPPT anyway due to 120v minimum requirement
Is there something I'm missing? Are there any other considerations I should make? What are your thoughts on my ramblings and do you have any suggestions?
