csp99
Not only do I not have a battery hydrometer, I had no idea they existed. I will do that.From what I'm reading here, the fact that you can check the water levels means these are NOT AGM, but flooded lead-acid.
Which is perfectly fine. The advantage of flooded is that you can read the specific gravity of each battery cell and determine the battery's true state of charge. You can also use the SG to evaluate the battery's health.
Do you have a battery hydrometer? I use this one, because it has temperature compensation. Basically the gold-standard for flooded battery health/charge.
Deka East Penn 00231 Glass Temperature Correcting Battery Hydrometer | eBay
Deka East Penn 00231. Glass tube.www.ebay.com
Do this. Get the bank fully charged, and after completing the charge, take a hydrometer reading of each cell. A fully charged battery will have an SG of ~1.165-1.175. Maybe a bit higher for a new battery, and maybe a bit lower for older batteries. The hydrometer is also great for spotting a defective cell. Each cell should not vary by more than ~0.01SG. Maybe 0.005SG for a new, healthy battery.
If you've fully charged the bank and the cells have a significant variation, cell to cell, or if the SG average is significantly less than 1.150, I'd say it's time to replace them.
If it is time to replace the batteries, I'd suggest it's also a good time to pull out that bigger 60A controller, so you can charge the new bank with more amps. Remember, chronic undercharging is the death of lead-acid. Keep them at a respectable charging rate, and they will last a long time.
Thanks, guys. Learning a lot.
