Our 2.6 kw roof array has been damaged by wind and insurance has paid out. I have ordered an Iron Ridge ground mount that can hold 12 Q-cell 360w panels. I just ordered 12 panels but am considering changing to nine panels for wiring simplicity. 9 panels will give me 630 more watts than I currently have plus a much better winter angle with the ground mount (18 degrees for current roof mount vs. 35 degrees for ground mount).
I have been told that with Schneider's 100a charge controller that I can put 9 360 watt panels in series with a 14 gauge wire run to the charge controller and be fine. However, I want the option down the road to expand the system to 12 panels (2 strings of 6) and use the same wiring to the charge controller.
I was told the 100a CC has three different inputs that are in parallel to each other. I have no desire to have two 100' wire runs.
If I want to have 2 strings of 6 in the future can I just put a combiner box at the ground mount with one wire run to the CC just like my current 60a Schneider controller?
If this works what size wire should I use (assume it will be in liquid tight conduit).
Thanks.
PS: I have to stick with Schneider because I have remote configuration/monitoring working just the way I need it.
Thanks.
