If you have any questions, you can contact me at any time. I will keep in touch with youNow top balancing them as per @Will Prowse video using my super duper new power supply.
Thank you for your support. Please contact me if you still need to buy.
I plan to hold a discount activity. The price of ETC277Ah is very good now. If you buy 16pcs, the price is 69 dollars; if you buy more than 48pcs, the price is 68 dollars
Ok, I'd love to chat with you. I sent you a messageThank you sir! That is a very competitive price. I am happy to see that a few forum members recently received orders from Senberry, it looks like good quality so far. Once they complete initial tests, I think there will be more interest.
Do you have datasheets available for CATL or ETC (CATL 200 Ah and ETC 277 Ah). You can private message me if you prefer.
Unfortunately my luck has changed somewhat with these cells.
I did the top Ballance to 3.65v, assembled in to a 16s pack and did a capacity test, this went well and I recharged and put in to service with a charge profile that was from 20%-90% end voltage of 57v . I have been away for the last few days so left the batteries to charge up with my PV, i came home last night and the cell voltages were all over the place, from 2.9v for the lowest to 3.8v for the highest according to my chargery BMS, the pack has gone through two cycles while away and has delivered according to my inverter 12.9kW overnight per night. I'm not sure what's going on here with mine. Ive doubled checked all connections, bus bars etc and they seem fine. the IR of the cells seems to be quite different but im led to believe I can trust the built in IR measurement of the chargery
I have two banks of 16 cells parallel 280ah without a bms, but I did add an active balancer on each bank that I can monitor with my phone.Unfortunately my luck has changed somewhat with these cells.
im doing them 2 packs at a time, testing them and then will put the full 32 in 16s2p. currently working on on 16s pack.You said you got 286ah when you tested the pack...that was a 48 volt pack right? But you received 32 cells? How did you configure your pack?
As for the rest I have no clue. I don't know anything about the Chargery. I would be very surprised if there is a problem with the cells.
This is a picture taken just about 17 minutes later with a load of 600 watts only. You can see my point that cell #16 is now the lowest, and if I apply a good load it would go down really fast to maybe .050 v lower than the rest. View attachment 21762
Thanks for sharing. I noticed in the other thread you top balanced the cells individually. I wonder if there is a difference between using that method and parallel top balancing. Also could you post the link to the active balancer you are currently using? Thanks.
so here is the problem, although it measure exactly the same voltage as the rest of the pack at 3.35v its hugely bloated and rounded. i presume this cell knackered. I've checked the chargery log and no cell has gone above 3.8v on a charge cycle so confused unless my bms is also shot
Its so bloated the bus bars wont even reach across now, once i undone the clamp system holding them together it sprung apart from the adjacent cell. the other 31 cells are all ok and both packs have gone through two cycles.
And whether these voltages have been confirmed with a multimeter?i came home last night and the cell voltages were all over the place, from 2.9v for the lowest to 3.8v for the highest according to my chargery BMS
Are you saying IR between cells is quite different? or the IR is different than initially measured during testing?I'm not sure what's going on here with mine. Ive doubled checked all connections, bus bars etc and they seem fine. the IR of the cells seems to be quite different but im led to believe I can trust the built in IR measurement of the chargery
Steve S said:The EVE 280 and other similar cells selling for the lower prices such as $80 per 280 cell are Voltage Matched, within "factory specs" for IR at test voltages but these are not fully "matched" up cells. That is a rather more involved process which cycles the individual cells through charge/discharge while validating the various IR readings through the cycles, at which point cells are sorted/categorised by their values and those that fall outside of spec (over or under) hit reject.
Steve S said:They are NOT fully Voltage & IR Matched, they are within the "Grade-A" spec though. You'd day 2x to 3x more for matched cell bundles. You do want to run these in straight series. Some have had luck and others have not but you are forewarned.
Steve S said:I have found that with these EVE 280's which are Grade A & Voltage Matched (not Internal Resistance Matched) they do tend to meander, meaning the cells will diverge and have volage differentials. This is most pronounced above 3.5V per cell. or during Heavy charge/discharge and passive balancing can't keep up to that. On "average" 1 millivolt per AmpHour capacity seems to be the norm. I have not done Active, only Passive balancing, and am now getting into the Active Balancing of my packs.
Yea, maybe a bad cell. But...
I cannot help but wonder if charging all the cells, 16 cells in parallel for 15 hours, applying the charge to a single end of the parallel bank had any bearing on this. It would be interesting to know if the bad cell was positioned on either of the ends. I do not see any cell labels so I am guessing there are not any notes at the cell level for the top balancing and battery build.
There might have been something to learn as a collective from this, or maybe just a bad cell. We may never know.
That said, I shouldn't think that moderate differences in IR could lead to the extreme divergence in voltage you noted, or the bulging at normal SOC. For me at least, there are way too few details of your situation to make meaningful speculations.
I recommend using letters like A, B, C ... because it gets confusing when you write notes about cell numbers referring to their position in the battery.I definitely will label mine when I receive them.
Also, labeling before unpacking can retain a little more data of that grouping.
