Thanks Neil, do you have a picture at all showing the busbars connected to the board ?The v3 connects only to the negative side of the battery and there is a small screw terminal on the bms for a positive feed (B+)
The positive from the battery feeds directly via fuse to the invertorView attachment 189046
You fitting it to a Mason?Thanks Neil, do you have a picture at all showing the busbars connected to the board ?
Mason horizontal.You fitting it to a Mason?
Horizontal or vertical ?
That looks like the V2 kitThese are the busbars that came with it.
Radio silence from Seplos so far. ?
And awaiting a reply from Frogstar.
So I have a v3 board with v2 busbars ? ?That looks like the V2 kit
That's right they do need a bit of bending also put the fuse in 1stThanks for taking the time Neil, much appreciated, but that doesn't look right either.
N2 won't reach the battery from there and N3/N5 wouldn't fit either .
I'm not convinced I even have the correct busbars.
I'll have a go at connecting the busbars this afternoon without connecting up to the battery to see if they fit.N2 (B1) goes the other way (points to the right
sorry
it isThat looks like the V2 kit
this is the positive supply to the BMS as the other main leads are only negativeI'll have a go at connecting the busbars this afternoon without connecting up to the battery to see if they fit.
Do you reckon then that nothing actually connects to the small B+ screw ?
Or is it maybe something to do with the active balance board ?
its notit is
Yes, there is. About 48cm long. ?this is the positive supply to the BMS as the other main leads are only negative
should have a short red lead with a large round terminal on one end and a small on the other this connects to the positive on the batteries
