Good, don't worry about alarms, these are just telling you your pack and every cell is almost full .
Now connect your inverter, charge until overvoltage disconnect ( warnings will turn red ), then discharge completely until low voltage disconnect ( again red, make sure to not connect the inverter comms)..
Your BMS will be calibrated, then connected comes, charge and use normally, SOC should be very accurate, and comm will tell your inverter to slow down charging to 10a as soon as the yellow alarms pop up, therefor helping in the balancing and making sure the inverter shuts down charging long before the BMS has to disconnect hard ( which can hurt the FETS)
Seems you are well underway !
