Off Gridin' It
- Dec 11, 2020
- 102
I’m looking at a setup for my new house in which the meter feeds into a service entrance rated 200 amp automatic transfer switch designed for use with a generator but with solar on the other side rather than a generator. The ATS would sit between the mains inputs and the main panel so this is not a critical loads sub-panel it will feed the main panel.
I will put solar on the “utility’ side so it has priority and utility on the ”generator“ side where if the solar cuts out for any reason, it would switch to utility and then switch back to solar when that power feed comes back up.
I have seen the Generac ATS but not sure if it is proprietary and if it is proprietary it won’t work.
Is there a standalone ATS that will work for any brands for use with solar and utility that is service entrance rated for 200 amps on each input that is available?
