I've been dealing with Emily, and she sent me everything I asked for, including the full overkill instruction manual. What bms did you get?Hi
Recieved the JDB, but no guidance or info about how to set it up. How to connect to Bluetooth?
Tried asking company - but they don't answer any questions at all - even if they claim to answer within 24 hours.
So I can use same program for the JDB as is shown and used for the Overkill?Go to overkill solar. They are custom jbd bms's and steve has a very well put together manual.
Thank you ?I've been dealing with Emily, and she sent me everything I asked for, including the full overkill instruction manual. What bms did you get?
Is that a programmable BMS?Thank you ?
But can I just use the manual 1:1 even when I don't have the Overkill?
I got the large 200A version
It might actually not be.Is that a programmable BMS?
So it seems it cannot.Default protection parameters (which can be adjusted by us
I bought the 150A version. I know the overkill instructions are not for the bigger models, but the set up should be the same. Did you get the spec sheet?Thank you ?
What are the solar controller charge voltage settings, the model of batteries you have, and method of controlling alternator power. These details will help.
The most likely issue is cell overvolts shutting down the charge path.
Any screen shots of BMS settings and status reports, if Bluetooth type, will also help.
Mike
solar controler voltage settings are 29v as its a 24v system so its my opinion it the bms shutting batterys down at solar charging only time not solar controler i have no control of my alternator external regulater apart form being able to put it in forced float mode when batery alarm goes off when voltage gets to 27.3v my batterys dont have blu toothWhat are the solar controller charge voltage settings, the model of batteries you have, and method of controlling alternator power. These details will help.
Mike
