Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,856
Those cables leading to the pack never went under that shelf bracket and they had enough slack on them that if the shelf/bracket broke and it dropped they still would not have been out of length and pulling on the breaker.
The breakers were for Positive and Negative.
If the weight of the pack were too break the shelf it would have been the other end where the battery weight is all going from middle to back of the shelf, the front end was barely holding anything.
It's really hard to tell what damage was done during the event and what was done from the chemical extinguishers, but if the panels were really struggling with the weight then being soaked and sprayed I would have expected all or at least some of them to have given in and collapsed.
I'm not sure what happend in the end, and I'll have to spend a lot of time cleaning it all up.
It looked to me like the cables went to a battery pack that sat on the shelf that was supported by that bracket.
So I hypothesized that the shelf gave way allowing pack to fall which pulled the wires down onto the bracket cutting into the insulation and allowing the positive/negative to short to each other.
250 amps on the Daly @ 48 VOLTS is like 12,000 watts of heating into those two cables plus whatever backfeed made its way through the 300 amp breaker from the other packs.
You potentially had 300 amps breaker plus 250 amp bms for a grand total of 26000 watts into those cables, right?
But you think the cables were long enough between the breaker and battery pack to prevent them from being strained against the top of the shelf bracket if the shelf let go and allowed the battery to drop?
If so, how did the the burn marks on the top of the bracket happen and why did the cables melt in half?
Edit: Point being, lots of heat can be generated without reaching the limits of the BMS(s).
