There is nothing in the NEC code that says current can't flow through a ground wire. I've been dealing with the NEC since 2006. In fact, in the US there are many old houses that use the metal conduit as the grounded neutral conductor, and others where there is only 1 grounded conductor, running throughout the entire building. Current flowing in a ground wire is only a problem if there is a poor connection that allows that current to turn into a voltage potential relative to ground. Good solid connections and properly sized wires avoid this concern, so there is no problem.
