With these high tech, multi-function inverters and rack mount batteries all connected and communicating, shouldn't stuff just work?
You'd think in this day and age, with a laptop or smartphone that you could just run through a simple setup wizard where you select the battery model, split phase parallel function, and boom...done. There should also be safe, conservative defaults that simply work, then you tweak from there.
