Yes, thanks for guidance. Sometimes knowing how to ask helps. 48v in an s, have 6 used 289w panels 3 each in series. The main load is a beer brewing system that is used for about 5 hrs used 5.5 kWh and peaked at 1473w. this will be used when other loads are not in use, power tool battery charging, garage door opener, pellet grill… Of course temp control on charging, Didn’t know they did some of the other things you listed. Have a mppt lv5048.
