Casper8572
Would it make more sense to cut the 110v plug & wire its ground, neutral, hot directly to wires from shore power inlet mounted on van? or directly to transfer switch? I’m confused why I plug this into an outlet powered by my AC breaker panel via inverter.
This is for an off grid van conversion, that has a 30 amp shore power inlet (10/3 awg), a transfer switch wired to AC main breaker panel which is hard wired to 3000w inverter, my battery charger is wired directly to battery main positive & negative terminals.
