I was hoping that my problem could be solved with an Easy Start
no where I can find have you stated what your problem is..... that would help over a random single sentence post.I was hoping that my problem could be solved with an Easy Start
Can anyone tell me if this 12K mini has an inverter or is it a hard start?
Is not an inverter mini
Frikko is from MexicoI've never heard of that brand before, Frikko... If you could start it up with an amp clamp on the input (one that can measure surge), you could see what is the max draw on it when it starts up.
But soft-starters only work on AC motors/compressors, not sure what kind of motors are in your Frikko, if they are DC, and they are starting with too much surge, it would seem like a poor design that the motor controller wouldn't be ramping it up gradually...
I listed the specs in an earlier post
My 1200 ah lead acid with a 3000 watt pure sine will not start the Mini so I have been trying to find an alternative to replacing the unit
3000w inverter should have like a 5k surge. and that unit should be less then 1200w ... I think u have a inverter problem check voltage in and out during start up or other heavy loads like a space heaterFrikko is from Mexico
12000 BTUHow many BTU is that Frikko unit? Is it 240v or 120v? Yeah, I'd try an amp clamp that can measure surge and go from there, then you can know what the unit is demanding exactly. Figure out where exactly in the unit is most the draw coming from. Like say the compressor, or fans or something. If they are AC or DC. Perhaps the fans are all trying to engage at the same time as the compressor. Maybe a delay on the fan relays for a few seconds, until the compressor is done getting up to speed would be enough to not trip the inverter? I don't know, just shooting ideas out there...
